Old 01-22-2013, 12:08 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by doru View Post
...Maybe the wagon has the same issues? One way to find out is to visually check.
It does...and I'd definitely check once you can get the tail gate open. If memory is correct...I think you can open just the glass lift gate...look to the far right and you should see a loom that goes into the roof of the car. You may have to remove some of the small cover pieces on the right hinge to access the loom.
Q {BMW CCA Member #191509}
(SOLD)
