01-22-2013, 09:08 PM
Mein Auto: 2001 BMW 330i
Originally Posted by AlboBMW
A big thank you to all of you who have participated and helped make this a great thread. Thank you especially to OP for his research and hard work.
I did this job this past weekend, and I can't tell you how nasty and grimy the "lifetime" fluid was. I got so dirty changing the fluid that I didn't have time to take pics. My cas has 162K miles. I noticed smoother shifting after the fluid change.
I used Valvoline MaxLife.
Once again, thank you all.
Totally.
I have 154000 miles. I did an oil and filter change at about 70k miles. I drained and filled a few times since then.
As far as the tranny goes, all has been good.
I have used Valvoline MaxLife everytime.
Apparently I am getting a bad torque converter seal code. I am curious if the Valvoline caused the bad torque converter seal. Anyone else have this issue with a Valvoline fluid change?
In any case, my tranny is still good. So that's cool. I just erase the code with my scanner and it stays gone for several hundred miles. So I guess I'll just drive until I have a real issue.
But thanks for this thread!!! Well done.
