Old 01-23-2013, 03:39 PM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
Replacing Clutch & Trans - What else to replace
Hi All, I need to query the collective expertise over here.
My transmission and clutch are being replaced under warranty. Currently I have just under 43k miles. I don't have the final list of parts, but I know they are replacing clutch, trans, ball pin, spring clip, & mounting bolts.
While the dealer has everything apart, what should I pay out of pocket for them to replace? I am quite certain I should replace items #1-3. Not sure what to do with the flywheel or if there is anything else I have missed.
1)Pilot bearing
2)Throw out bearing (is this part of the Release Module?)
3)Clutch Fork (is this the release module?)
4)Flywheel (dealer said this isn't covered under this repair) Replace or resurface?
Transmission:
No. Description Supplement Qty From Up To Part Number Price Notes Photo
01 Guide bush 1 23117537909 $53.42
02 Torx screw M6X12 4 23117531355 $1.80
03 Shaft seal 70X39,85X9 1 23127501712 $15.29
04 Cover lid 1 23117537911 $8.67
06 Screw Plug With Gasket Ring M18X1,5 2 23117531356 $7.44
07 Shaft seal 62X50X9 1 23121282458 $15.29
08 Breather tube 1 23117537913 $6.53
09 Shaft seal 15X21X5 1 23121282394 $10.02
10 BACKUP LIGHT SWITCH M12X1.5 1 23147524811 $11.00
Clutch:
01 Set Rmfd-clutch parts twin mass flywheel 1 21207567623 $407.69
only in conjunction with
-- Set of alu. screws manual transmission 1 23000417164 $13.00
02 RMFD CLUTCH DISK F.TWIN MASS FLYWHEEL D=240MM 1 21207526516 $130.67
03 Release module 1 21517564027 $75.34 See MH 0038916
04 Fillister-head screw, micro-encapsulated M8X18-10.9-ZNS3 6 21207548052 $0.48
05 BALL PIN H=20MM 1 21511223328 $1.17
06 Spring clip 1 21517570284 $4.50
ID:	358944   Click image for larger version
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
