Old 01-25-2013, 06:29 AM
Titaniumseeker Titaniumseeker is offline
Mein Auto: DINAN 7
First look appears to have the DINAN Cold Air intake and also MAS. With that you can also assume that there is at least a Stage 2-3 engine software installed unless other components were also added such as exhaust, throttle body, intake, etc. The vehicle doesn't become a DINAN 7 until a certain amount of points are accumulated associated with the parts/ accesories installed. DINAN should be able to tell you, via your VIN what was installed in your vehicle. Good Luck!
