01-25-2013, 08:56 AM
Mein Auto: 318is 2.5i
Originally Posted by hornhospital
You didn't swap in an instrument cluster for a 6 at the same time you replaced your 4 with a 6, did you? The 4 cylinder cluster will work, but it won't read correctly. You need a 6 cylinder cluster. Also, it sounds like your connections on the IC are loose.
Difference in 4cyl and 6cyl cluster is just how right rpm-s are, and I changed them also. This problem occurred on both clusters. Probably not connections cause both clusters had same issue and this is somethings to do with engine temerature?! Or somethings with electrical system...
