Bimmerfest - BMW Forums - View Single Post - No Heat-Blows Cold Air Thru Side and Center Vents
Old 01-25-2013, 09:18 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Originally Posted by QSilver7 View Post
We have to ask since you didn't tell us that it was ruled out as the culprit like the OP did in the 1st post in this thread "dial is set to red".
What position do you have the stratified air dial? This is the dial (#3) in the middle of the dash's center vent that allows the front passengers to "temper" the air from those vents warmer or cooler...independent of the set temp that is coming from the floor or defrost vents.
That's what happened to me when I first try using the heat in the X. Finally read the owner manual and found out about the thumbwheel in the center of the vent.
