Old 01-25-2013, 10:46 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
An intake will definitely help you with hp/torque gains as well as throttle response. As others have mentioned, you'll also hear the turbo spool a little more as well. I'd recommend that you check out the aFe Stage 2 Intake System for your BMW 335is N54.
The aFe Stage 2 Intake replaces the factory air box which allows for increased air flow. This modification will be an improvement over the stock box and on a stock car. It is also a great compliment to a aftermarket exhaust systems as well as aftermarket tunes. Another feature of the intake is the 16 gauge powder coated steel heat shield. A heat shield makes sure that the intake doesn't use the hot air around your engine and only allows the intake to receive cooler air, which adds more power. Not only does power increase, but many have observed an increase in MPG.
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
