Bimmerfest - BMW Forums - View Single Post - F10 TPMS PSI/Temp Data - Working or Not
Old 01-25-2013, 12:25 PM
Lanman2012 Lanman2012 is offline
Mein Auto: 2012 550i M Sport
Originally Posted by shawnsheridan View Post
This only works with TPMS, Option 2VB.
1) Go to www.bmwvin.com and put your Short VIN in an make sure you have 2VB.
2) Assuming you have 2VB, make sure the following is coded:
ICM:
IcmKod_B_SA2VB = verbaut
CIC:
RPA_CIC = nicht_aktiv
RDC = aktiv
RDC_SAFETY = aktiv
If you do not have 2VB (TPMS), RPA_CIC (FTMS) should be aktiv, and PSI/Temp will not work.
If you have 2VB, and all the above coding is correct, and you still do not have PSI/Temp, your screwed.
I just tried coding this feature and unfortunately it's not working even though I do have the 2VB option. All I'm getting are the the three dashes. I tried verifying the above settings recommended by Shawn but I was unable to find the IcmKod_B_SA2VB key. This is my first time coding though so I might not be looking in the right place.
Anybody have any advice on what to try next?
2015 550i | M Sport | Space Gray | Black Nappa | Anthracite | Executive Package with B&O Sound | Dynamic Handling | Driver Assist Plus | Lighting | Cold Weather | Luxury Seating
Prior
2012 550i ( retired )
2008 STS-V ( retired )
2004 CTS-V ( retired )
