Bimmerfest - BMW Forums - View Single Post - 318is Engine swap results Tachometer failures
Old 01-25-2013, 12:50 PM
RaunoV RaunoV is offline
Mein Auto: 318is 2.5i
Originally Posted by B1MM3R View Post
Are you sure you have a 6 cylinder cluster in the car now? B/c range will be off if not.
Yes, old 318is cluster showed way higher rpm-s. With this cluster rpm-s are normal.
But does that matter that i have 525 ECU? As new engine is older and they don't match with OBC?
