01-26-2013, 11:16 AM
Mein Auto: 2000 BMW 328i
Originally Posted by G. P. Burdell
Adhesive-lined heat shrink is my wrap of choice; these days, I only reach for electrical tape as a last resort. Those strips of black tape holding up the wire harness will fall off in no time.
sjbmw328i - It looks like you are missing the center splash panel and some other plastic bits under the front end. You might want to consider installing them, even if you do have an aftermarket front bumper cover. In addition to providing a proper mounting location for the OE ambient temperature sensor and heated washer nozzle temperature switch (if installed), they help protect the bottom of the engine against dust, water splashes, and small road debris.
M last OEM temp sensor was in the exact same spot zip tied in the hole when i found it. I didn't know where to put mine at, so I just put it in that same spot. Are you referring to the "Engine Splash Shield?" Yeah I am missing that part. I bought the car and it was already like that.
