Old 01-27-2013, 06:01 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
There should be a couple of small holes that you can use a drill or paper clip to hold the brushes in the holder until the brushes are installed. Once install you just pull the drill or paper clip out and the brushes will come into contact with the rotor shaft.
In this video, the repairman uses a tooth pick to retain the brushes.
