Old 01-27-2013, 07:18 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
Originally Posted by Mr745i View Post
Here ya go. this euro cluster is up for sale if anyone needs it.
Mr745i, I assume you followed Nygel's advice and just swapped the electronics from your original cluster into the US Spec MPH cluster?
Originally Posted by Nygel View Post
What ever gauge cluster you get you will need to take the electrical board off of your orginal and install it on the new cluster, then reinstall back into the dash.
All of you KOMBI information will be retained and no programming needed.
hope this helps
Nygel
Nygel, any idea if just overwriting the VIN in the used cluster (via NSCExpert) is sufficient for it to take over the Odometer reading stored in the CAS module? I am assuming the Odometer reading in the CAS is greater than that stored in the used cluster.
The training PDF in the DIY section has the following statement:
"Note: In the case of a used instrument cluster (vehicle identification number is entered), the vehicle identification number can be overwritten up to a kilometer reading of 254 km (158mi). A reset of the permanently stored mileage reading is not possible."
But often I find limitations listed in the training literature are just limitations of DIS and Progman.
