After checking the above mentioned I would check if the fuel injectors are leaking. Order some new o-rings, remove them and check you tube for tutorials how to check them and clean them also. There are a lot of videos. If you want to find which one is leaking you could check the spark plugs for deposits.
JOY = BMW
