Old 01-28-2013, 11:05 AM
hunter94 hunter94 is offline
Mein Auto: 1993 BMW 325I
Try spraying a bit of brake cleaner where you think the vac leak is. Once the cleaner hits the leak your engine will rev up. Also check on the underside of the air intake I had a leak there one time. The only reason why I found it was because I used the brake cleaner method. Be careful where you spray and be conservative. Keep us posted.
