Bimmerfest - BMW Forums - View Single Post - Intermittent car battery drain problem NEED HELP
Old 01-29-2013, 01:27 AM
Usy2007 Usy2007 is offline
Mein Auto: Bmw 318i msport convert
Joegr - also what you mentioned about disconnecting the battery would stop the drain until another spike occurred.. I dont think this is the same case with mine as when i was testing the draw, i disconnected and connected the battery several times.. And the drain remained until i pulled a fuse..
