Bimmerfest - BMW Forums - View Single Post - Intermittent car battery drain problem NEED HELP
Old 01-29-2013, 09:40 PM
Mein Auto: '04 330Ci 6-speed
It is my experience that whenever I use the OBC functions to measure voltage, the alternator output is usually 14v or a little above even at idle.
It's just one car's experience, but it would indicate that your car is not charging with a healthy amount of power. And I think it could be a less than perfect battery or the alternator. Of course it could be just the voltage regulator if you wanted to try to economize.
Just for a check, do you turn everything off when you do this test, including the HVAC system completely off?
This would not cure what ails you as you still would have that parasitic drain.
