01-30-2013, 11:59 AM
Mein Auto: BMW e39
Originally Posted by acoste
Hi Nakoye, your problem is definitely the P-BUS connection between the drivers door module and the general module. Search for the P-BUS line on that connector and make sure it's o.k. Even if it looks nice, it might have some oxide on it making the resistance higher. Contact spray helps.
Hello Acoste,
thank you for your help, but I think that i made a big mistake with that contact spray and the cleaning procedure, because I made a spark between two pins(I forgot to remove the battery) - how I can understand if I burn something and how to reapair the problem. Thank you again.
