Bimmerfest - BMW Forums - View Single Post - Cooling System
Thread: Cooling System
Old 01-31-2013, 12:45 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Originally Posted by SFbay View Post
Asia??? Hmm do I sound Asian??
Ha ha I'm no darker than you
If I were you I would do the rear plate for this money, bc you have no wheep hole leak, may be vp leak.
Keeping fingers crossed wont do anything, and thinking that rear plate for some miraculous reason is still normal after 10yr ??? It's no different from valley pan, same exact design and is prone to failure. M62 has a crossover pipe, which you can replace easy after intake removal. N62 sucks at this point!!!
Did you know they had e65 with straight 6 M54 and M57 in Europe??? Imagine problem free e65!!! V8, V12 is not very popular there and is expensive.
Sorry I can't understand this post, I think your asian accent is coming out in your typing?
Anyway, a quick way to test the valley pan/rear plate is pressure test the system, if theyre leaking you will see it right off the bat.
