Bimmerfest - BMW Forums - View Single Post - Is that a catch can? Yes it is. Goodbye CCV
Old 01-31-2013, 05:42 PM
champaign777's Avatar
re-read entire post
dump !
Why not to use the best of OE BMW CCV and just implement what was suggested by our GURU CNN long time ago
THIS :
If the Intake Manifold sits above the Valve Cover, then the design is simple.
Reuse OE CCV + implement CNN suggestion to have Manifold above the Valve Cover by another connector from Valve Cover to Manifold
You will have the best of both , - no oil coming into CCV due to U-turn and right vacuum pressure designed by BMW !
I would first try this SIMPLE solution before anything else !!
