The (future) AGA secondary air port cleaning kit will only fix the "secondary air low flow" error message. The fault is generated due to carbon build-up in the heads that clog the port at the exhaust valve. The carbon build-up is due to the leaky valve stem seals. The AGA kit might allow sufficient cleaning of the ports to make head removal not necessary, but at $250 it is about the same cost as removing the heads DIY when you figure in head gasket and head bolt parts cost. Plus, pulling the heads ensure a better job of cleaning than using the AGA kit. IMHO.
