Old 02-01-2013, 09:32 AM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Originally Posted by BashedBarrique View Post
Well the car wasn't submerged or anything. As far as I can tell the carpet just got wet and the condensation accumulated in the trunk from sitting closed up for a month.
Are BMW's such delicate hot house flowers that you can't leave the sunroof open in a rainstorm without selling the car for salvage?
Well, I won't speak for BMWs, but I do know that more than one B5 series Passat (same time frame as the 2006 325) went toes up for just that reason. If you put a quart or so of water in the passenger footwell, you would start killing modules.
Do I think getting rain in is a guaranteed problem? Not if you dry the car out right away, but that doesn't sound like what happened here. It sounds like it got wet and was left that way. I would guess that if it was condensing water in the trunk, it was condensing water elsewhere, and that's certainly not going to help anything.
The BT cable does have a strong following here, and Orient's fuse check is certainly a fast/no cost thing to hit today.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
