Bimmerfest - BMW Forums - View Single Post - Spoiler Or No Spoiler
Old 02-02-2013, 06:58 AM
JPetrillo JPetrillo is offline
Mein Auto: 2013 528xi
Originally Posted by Skinfan31 View Post
Looks Great! Any issues?
No issues whatsoever. I love it and I'm very happy I decided to do this mod. It's a very subtle addition, but it effectively spices up the rear and gives it some life! The pictures came out okay, but as always, it looks even better when you see it in person.
Did your spoiler come with a roll of 3M Automotive Tape? I used almost the entire roll. I lined the tape along the bottom of the spoiler so the bottom was entirely covered in tape. When you get towards the two ends of the spoiler where it gets very narrow/skinny, just cut a strip of tape in half down the middle to make two skinny pieces that will come almost all the way to the tips.
Once I had the bottom of the spoiler completely covered in tape and ready to be installed, I used a Windex/water mixture (50% Windex / 50% water) to dampen the trunk. I recommend this, but don't use a lot. All you need is just a tiny bit of solution on the trunk to add some moisture; don't add so much where it's dripping wet. This will allow you to slide the spoiler into position to get it perfectly lined up. Once you have it in position, press down firmly and hold it there for a minute or two. At first, it will feel like it doesn't want to stick because the trunk was somewhat wet. However, just keep holding it in position and pressing down and eventually it will stay in place by itself. At that point, either let it sit to dry, or do what I did and take a hair blow dryer to it. I ran the hair blow dryer up and down the spoiler for maybe 15 minutes, and after that it felt super glued to the trunk. That spoiler isn't going anywhere.
2013 528i xDrive Black Sapphire Metallic
Mods:
35% Madico Onyx Tints
Painted Front Reflectors
Debadged
Custom M Performance Grilles
M Performance V-Spoke 20" Wheels
18mm BMS Rear Spacers
M5 Style Spoiler
M Sport Rear Bumper with Painted Reflectors & M5 Diffuser
GTHAUS Meisterschaft Full Cat-back True Dual Exhaust 4x90mm GTC EV Controlled
Evolution Racewerks Catless Downpipe
BMS Stage 1 Tune (pending)
(Picture not up to date with current mods)
