Old 02-05-2013, 05:48 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Originally Posted by HPIA4v2 View Post
It's pretty much the same AWD system as the one in 535xi, it's referred to XDrive nowadays. my 335 coupe rear emblem even says 335i and on the front fender it says XDrive. Not sure why BMW delete the xi emblem, it's probably just marketing.
But this XDrive is for sure uses more elctronics to control power coupling from rear to front when slippage detected. But it's very light compare to worm-drive Quattro systems for sure.
Yes BMW finally decided to put AWD into x50 class, but not in M cars yet.
It might be light compared to other systems, but actually it adds 200 lbs to the car's base weight. It's like driving around with a heavy passenger next to you.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
