Bimmerfest - BMW Forums - View Single Post - 07 530i jerk forward when coming to a stop Please HELP
Old 02-05-2013, 05:12 PM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
I was thinking you had a 530i for some reason.... Since you have a 545i, that's a different story... That rough cold start idle is usually due to your minimum valve lift adjustment. It's set at 0.3mm from factory. I set it 0.8 and raise the idle about 50 rpm when I come across this complaint.... You would need a bmw dealer scan tool to do it... Not sure about the aftermarket stuff
