Old 02-06-2013, 06:37 PM
HerbP HerbP is offline
I would suggest at this point, to see if the truck mechanism is stuck in the open mode with a VOM. This would allow you to open & close the trunk emblem, & watching the VOM react between open & closed. You could also use the VOM to measure voltage at the plug, to determine if it is getting power.
Good Luck!
