Old 02-07-2013, 01:08 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
This is a known issue. There was a part change on the cap after '10 I believe. One key thing is to keep the cap rubber ring clean as well as the mating surface. Make sure neither surface is dry, or the rubber will bunch up. You can also gently bend the fasteners to make a tighter seal.
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
