Bimmerfest - BMW Forums - View Single Post - BMW 650 2008 - Battery Replacement Specs
Old 02-07-2013, 02:25 PM
bmwoem1 bmwoem1 is online now
Past Sponsor
Mein Auto: X3
The car would only have to be programmed if you change from white battery to black AGM battery.... The only reason dealers started doing this is because the supplier for the white batteries couldn't keep up, the problem has been rectified for now (I work at a dealer).... So If you get this replacement done at the dealer, it may not be as expensive as you thought
