Bimmerfest - BMW Forums - View Single Post - Gas on the Dipstick?
Old 02-07-2013, 07:23 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is online now
Mein Auto: 1989 E30; 2000 E38; GS350
@nicholasb
Did you ever get your problem fixed? Did you check the fuel pressure? If the fpr doesn't fix your issue, you should also look at the cold start valve and injectors. Check the cold start valve or injectors' ability to hold pressure after the car has been turned off. Leaky injectors drain fuel directly onto the piston and in the oil. This might be the cause of the fuel smell on your dip stick.
Big Boyz with Bad Toyz.
