Bimmerfest - BMW Forums - View Single Post - What's with the E60 Rear Turn Signals?
Old 02-09-2013, 02:49 PM
dbond698 dbond698 is offline
Dougbie
Mein Auto: 650i Convertible, X3
Ran into a similar issue with my '04 545. I had to remove the front right headlight assembly to replace the angel eye bulb which was quite the PITA. About a day after fixed, I had the right turn signal malfunction error and the hyperactive signal inside. I had read about the bad connection so removed the headlight unit once again (pleasure) and removed both wire connections. I sprayed both (female and male ends) with electronic parts cleaner and worked them back and forth (plugging together) to work out any corrosion that might exist. After wiping the residual cleaner and letting them dry for awhile, I plugged them back together and tested it out - all working! We'll see how long it lasts but had been malfunctioning 2 days straight before.
