02-09-2013, 08:40 PM
Coupe OR Never
Mein Auto: '02 - 325ci
One of the wheel speed sensors (if you are lucky)
Or
DSC pressure sensor (mounted on master cylinder.) Not expensive or difficult to replace. Just need to bleed the system properly.
Or
ABS module (mounted on master cylinder as well). If this is the case, you will have to look at the rebuild options. Buying a new one is not much of an option
