Originally Posted by treeofgreen
... Today i fired up the car and all was well. Was driving ... then had to stop at a red light...heaps of smoke came out the exhaust. It billowed out for about 20 seconds then only small amounts were coming out ...
Here is a vid of when i went out to check after 30 mins of being off:
(just remove the spaces, wudnt let me post the link)
Originally Posted by upallnight
Could have been a clog in the Crank Case Ventilation system and you started sucking oil into the intake manifold. Ever had the CCV valve service or the oil separator?
If that was my X...I agree with upallnight and would check the CCV...your video looks like the classic failed membrane/diaphragm that tears/rips and allows oil to be sucked in to the intake...which then results in the oily smoke from the exhaust you see in the video you posted.
The video upallnight posted was for the N62 engine...which has 2 membranes on each cylinder head..which is also very easy to access since they are on top. But your X5 has the m62TU engine...and the CCV on that engine is located on the back of the engine...and is a bit more difficult to tackle.
Edwin (e38 owner from the Netherlands) who is an excellent DIY'er has a video up on youtube that shows how to simplify the CCV DIY job on the M60/M62/M62TU engines...take a look and also do the test with the oil dip stick & tube to see if you can hear the gurggling and feel the sucking from the tube:
Q {BMW CCA Member # 191509}
(SOLD)
