Old 02-10-2013, 05:59 PM
tamir15 tamir15 is offline
Mein Auto: 2006 750i E65
Originally Posted by Piers1989 View Post
Mayve the reverse light is powered by PWM, but the other lights normally are too, at least the exterior ones as far as I know.
I can offer a suggestion though.
If you get a standard automotive relay, attach it to the reverse light for the "on" and to the battery / continuous on for the +ve.
That way it will turn on when reverse light is on and it will supply power form a steady source.
Hope that helps.
Thanks Piers1989.
can you explain how to connect the relay to the reverse light wires?
should i connect one lead to the negative wire and the normally open lead to the positive wire? i know the relay has 4 or 5 leads but i am not sure which one to use and how to connect them
