Bimmerfest - BMW Forums - View Single Post - plizz help 2002 bmw x5 4.4i should i change my Trany fluid
Old 02-11-2013, 06:14 PM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
Originally Posted by pedja3 View Post
yes, 160k is too much, and i tough the same way but people say, if is not too high of mileage, you can do it. so 100K should be ok. i will take a risk. the hole life is a risk so i will try this thank you for your feed back davie F
The thought process of changing it at too high a mileage is sludge / debris has accumulated and a fluid change carries the possibility of dislodging it and clogging the various orifices. IMO you've got sludge / debris build up it's better to change the fluid than not.
My thought is those who experienced problems after changing the fluid either had problems prior to the fluid change or the change was done incorrectly.
