Old 02-12-2013, 02:14 PM
ankurg09 ankurg09 is offline
Mein Auto: BMW 530i
Originally Posted by bimmerrg View Post
What kind of tools are needed to remove seat? Do we need to just remove the 4 bolts or more? After the work done, are the seats going to stay tight without moving on stops?
4 bolts and cable coming from floor to the seat, I guess u need T25 socket ( can check and let you know or if you are in us you could just go to Autozone and they would test and give you one) you would also need a breaker bar and a ratchet. I did not remove the seat belt mounting screw since i just lifted the seat and kept it close to the car with belt extending(not sure if this is the right way).
After work seats are the same as before. Just make sure before unplugging any cable from seat , Remove the battery -ve terminal and let the car sit for 10 minutes (minimum).
For more info , I have attached the seat removal guide.
File Type: pdf Master_removing_and_installing_front_seat___normal.pdf (389.2 KB, 322 views)
