Bimmerfest - BMW Forums - View Single Post - Can I use L7 sub outputs to install better Subs?
Old 02-12-2013, 03:15 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
Originally Posted by bk750 View Post
I need help with this subs on the car. what subs can I put under the seat to replace the factory subs then I can use a loc to power the new subs under the seat
Earthquake QWS series I believe, its there flat woofer line and 8''. It has the bolt pattern for the BMW's for a direct drop in. But just a FYI there are more out there if you favor a particular brand but bolt patterns needs to be modified.
Remember the clean sweep will give you a balance flat signal so you can alter thru your amps so you will have the best quality and signal power, also I believe the llines are pretty close to being balance other than adding a balance line driver.
hope this helps
Nygel
