Old 02-12-2013, 10:06 PM
maxeaus maxeaus is offline
Mein Auto: x3
Originally Posted by reed75 View Post
So my fluid tank is now leaking and not holding anything so I'm assuming its this same piece your are speaking about. So how do I replace this? If I remove the tank will I see what needs to happen? Or do I not have to remove the tank to replace this part?
There is one bolt to undo holding the reservoir in place you cant miss it, its that simple, you will have to pull off the rubber hoses attached to the pumps or you can just pull the pumps off the reservoir, whatever is required.
2006 X3 3.0D
