Bimmerfest - BMW Forums - View Single Post - Temp gauge suddenly spiked to red Help!
Old 02-16-2013, 02:55 PM
H2oallyear H2oallyear is offline
Mein Auto: 1997 528i 5speed
Originally Posted by kmorgan_260 View Post
One thing you can do that sometimes gives a clue to the head gasket is to drain a little bit of oil into a glass jar. If there is any coolant in there it is usually in the bottom of the sump (cool engine) and you can see it in the bottom of the jar. You can also just lift out the oil filter and take a close look at the oil on the filter. If it looks milky that is a bad sign.
Good luck.
Thanks for the info. So you think the gasket and head could be damaged driving in the red for a mile or two at 1k rpm? I know it wasn't any further. Just asking. I have been driving off and on today and the coolant has not dropped below where it was first thing this am after last nights bleed and test run
