Bimmerfest - BMW Forums - View Single Post - Temp gauge suddenly spiked to red Help!
Old 02-16-2013, 03:19 PM
H2oallyear H2oallyear is offline
Mein Auto: 1997 528i 5speed
Originally Posted by kmorgan_260 View Post
I wasn't implying that you damaged the HG by driving while hot but maybe that was the cause of the overheating to begin with. No way to know but to just start checking and eliminating things as you go.
Ahh I see. I will check when I get home. Did the OB test and its running around 95-97 with a good hi rev run for 15 minutes. The expansion bottle has not dropped from where I marked it after my bleed and test run last night. It just might be time for a cooling system overhaul because at 118k Miles's all I have proof of is that the t stat and pump were changed. Replace it all for piece of mind I am thinking!
