02-17-2013, 08:38 AM
Mein Auto: 2008 535xi Sedan Auto
They are wireless sensors, no programming. All you need to do is reset your TPM, there is a setting for it in your heads up display under tires. You have to reset while your stopped and then just drive. Of course after you set the psi to your desired level. The computer automatically knows which one is where. Just make sure your tire with the biggest offset of 9.5 are the rear tires but any time shop should know this.
