Bimmerfest - BMW Forums - View Single Post - 2005 545i slight slip into 2nd gear?
Old 02-18-2013, 08:57 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
That tis it!
Also, in regards to using redline, I'm not sure how good it is to mix redline and OEM fluid, so that was another reason I stuck with OEM. You can only change about 6 quarts. The other 6+ is in the torque converter and valve body where it can't be drained.
It very well may not matter, but just a thought.
