Bimmerfest - BMW Forums - View Single Post - E39 speed sensor / abs issues!! help!
Old 02-19-2013, 06:36 PM
Sequence Sequence is offline
Mein Auto: 2001 525i
I had the EXACT same problem as you, code reader said speed sensor, swapped then it said steering angle sensor, swapped it...then it said speed sensor again. I saw a pattern forming so I replaced the ABS module, problem solved!
