Old 02-20-2013, 09:27 AM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Struts and shocks....could be just struts. Push down quick and hard on front corner and see if it does up and return to level...same on each side (and rear if doubt the shocks). Old rule is should be "no more than 1-1/2 movements. If more stuts or shocks are bad and you are depending on springs to absorb road bumps....and they will bounce if no good shocks and/or struts. e-bay actually has some reasonably good deals...autohausaz.com.
Local Parts Stores are usually a bit pricey...you drive a BMW!!!!
Last edited by jitsjaf2009; 02-20-2013 at 09:31 AM. Reason: forgot the az on the autohausaz.com
