Old 02-21-2013, 03:47 PM
CT's Avatar
CT CT is offline
GODSPD
Mein Auto: SSII E90 ///M, AW E92 N54
Originally Posted by gulshan View Post
I currently have stock Style 189 Rear: 18x8.5 offset 37 and tire size 255/35 18. If I add a 15mm spacer I get the exact flush look like I need. So if I want to avoid using a spacer should I be looking for wheels with offset 52 (37 + 15) ?
The math seems odd if you're not familiar with wheel and suspension geometry, but you'd be looking for ET22 (37 - 15).
Positive offset is a measure, in millimeters, of how far outboard the wheel mounting face is from the wheel centerline. Adding a spacer moves the mating face farther inboard so you subtract the thickness of the spacer from the wheel's manufactured offset to determine the new offset.
e90m / ssii / foxred / wedssport sa-55m 19x9.5 et24 square / kwv3 / 15mm rear spacer / no chrome
WHEELS FOR SALE
