Bimmerfest - BMW Forums - View Single Post - 2006 650i fuse diagram
Old 02-22-2013, 09:24 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Originally Posted by Pavelcbrrr View Post
Yesterday I checked if the sound is coming from the glove box when I press the trunk button and yes, it's small "click" not too noisy but hearable. On Saturday I will check one more time if there is any change on the connector voltage when I press the button. I'm not sure now, because last time when I was checking that, I was alone and it was quite difficult to do that alone.
I'll let you know
It is hard you are right it's easier if you
use paper clips to probe and alligator clips clipped to your meter. Then you can just push the trunk release on your remote and watch the voltage change if any.
Try your valet key lock before you do anything it will take only a minute.
Remember basic troubleshooting always do the easy stuff first.
Sent Via iPhone using BimmerApp
