Old 02-28-2013, 05:04 PM
MMME30W MMME30W is offline
Mein Auto: .
Originally Posted by edge9 View Post
This is directly from the E92 manual…
Knurled wheel for more or less cool air from the vents for the upper body area.
So if you have the automatic system set and it is heating the interior, you can turn the wheel and have relatively cooler air be directed to your face or upper areas if that is more comfortable. That being said I usually don’t mess with it.
Correct...The temp setting is for overall setting, the mix dial controls the air you get to your face...works well.
OP, welcome to the fest!
