Bimmerfest - BMW Forums - View Single Post - E91 w 116K miles --- coolant leak
Old 03-10-2013, 02:20 PM
be-em-veh-808 be-em-veh-808 is offline
Mein Auto: E91 328 Touring (SPP)
My E91 2007 has 117K Miles. I've had low coolant warnings twice in the past year. First time I only had to fill less than a quart. the second time, seems like half a gallon.
I looked down the engine bay and noticed that there's wet (likely coolant) spots at the bottom panel/tray. This is almost directly under the headlights towards the very bottom of the car. Something is leaking. Could it be the water pump? Or just hoses/connections? I need to open the panel up and inspect.
Does the water pump begin to leak prior to failure? Or does it just stop working?
I have not yet had high temp warnings. I'm very nervous because my daily commute is ~ 45 miles (1.5 hrs) each way on LA freeways.
Much thanks in advance!
