Old 03-14-2013, 12:39 PM
FultonBMW FultonBMW is offline
Mein Auto: BMW X5 4.4i (Sports Pack)
Oil Leak Quote Question X5
I have a 2006 BMW X4 4.4i (Sports Package) and I recently discovered I have an oil leak. I brought it to a shop and the mechanic gave me a quote that seemed high. Here it is.
Alternator Bracket N62 - Alternator support bracket leaking engine oil. Support engine, lower front subframe, remove alternator, remove power steering pump, remove bracket and replace gasket. Clean. ($1404.00 Labor)
Upper Timing Covers N62 - Replace timing cover and valve cover gaskets. Clean and top off oil. ($1350.00 Labor)
Steering - Replace power steering pressure line. Top off and bleed fluid. ($86.40 Labor)
Total Labor - $2841.40
Parts - $695
Can someone tell me if this seems reasonable or not? I would greatly appreciate it. Thank you.
