Old 03-17-2013, 03:13 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
Originally Posted by htn View Post
Thanks for the shots.
I was imagining the wheels would be sunk in.
Looks really good. I will be doing this soon.
Hope you don't mind sharing cost for shop to do the install.
Runs about $450 for install... and another $150 for BMW to do 4 wheel alignment after... well worth it just look out for dips in the road, curbs, and driveways!! One benefit... park sensors now pick up the edge of curbs but you have to turn them on when pulling up to one. Also, you'll want to adjust your headlights up a bit... Just mark the height on your garage door and afterwards adjust them to this level... The vertical adjustment screw for the drivers headlight is under a small plastic cap in the fender to the right of the light (when standing in front), the adjustment for the passengers is again to the right of the light inside the access panel for the lamp housing. The other adjustment screw moves the lights left/right.
Good luck!!!
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
