Old 03-20-2013, 11:49 PM
david831's Avatar
david831 david831 is offline
Cuztomizing
Mein Auto: 2000 BMW 528i
will these speakers will do for front and back? they are ROCKFORD FOSGATE P152 PUNCH 5.25" 2-way Coaxial Speakers
Configuration: 2-Way Full-Range
Midrange Diameter (in): 5.25"
Midrange Depth (in): 1.81"
(46mm)
Tweeter Diameter (in): 0.75"
(19.0mm)
Tweeter Depth (in):
Frequency Response: 70Hz - 22kHz
Nominal Impedance: 4-Ohm
Power Handling (RMS): 40 Watts RMS
80 Watts MAX
Crossover: n/a - tweeter has built-in crossover
Sensitivity
(dB @ 1 watt/1 meter): 87dB
or the Rockford FOstgate PRIME:
5-1/4" 2-way Prime Series Component System
Power Handling:
Peak: 160 watts per set / 80 watts each side
RMS: 80 watts per set / 40 watts each side
Mylar balanced dome tweeter with an in-line crossover delivers crisp high frequency response
Easy installation of flush, surface, or angle mounting
Mica injected polypropylene cone for extended frequency response and accommodates direct OEM installation
Foam surround allowing fluid movements for accurate sound reproduction
Perfect for original factory replacement
Stamped steel basket
Frequency response: 58 - 20,000 Hz
Crossover Frequency: 12,000 Hz
Sensitivity: 85 dB
Impedance: 4 Ohm
ID:	367449   Click image for larger version
ID:	367450   Click image for larger version
