Old 03-30-2013, 01:12 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Originally Posted by Makomagnet View Post
Not brakes, not fluid level, not DSC switch. Is there a fuse or harness I can check the the switch is sending a "turn off" signal ?
I think there may be multiple fuses due to there being underlying systems that work with DSC. Check the front fuse box (there should be a pull out fuse index card when you open the fuse flap in the glove box) and the rear fuse box (should be a fuse index on back of battery compartment door) and look for anything that has to do with ABS, ASC (automatic stability control), and/or DSC/DBC (dynamic stability control/dynamic braking control).
Again, there may multiple areas that a fuse related with traction control can be since ABS/ASC/DSC/DBC all work in conjunction with one another (not all e39s may have all of the systems aforementioned).
(e39 glove box fuses)
Check fuses #17/#30/#31
Q {BMW CCA Member #191509}
(SOLD)
